| | | Forums66 Topics128,077 Posts1,056,017 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Remove your Governor and make sure it is working. I had one where the pin on the shaft broke and the gear just turned in place. To test the governor secure it in a vise and insert the shaft in a drill motor. Hook up an ohm meter, one wire to the contact and the other to ground. Spin it up and it should peg the meter. If not its not working. Fred
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If all the wiring wrings out, take the governor off, remove the end plate and clean the contacts. Then be sure it is well supported, like in a vice, when you chuck it up in a drill motor and spin it up with ohm meter leads attached. (One lead to the terminal, the other to the governor body.) Spinning should give you continuity. | | |
