1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
#1015244 03/18/2014 8:32 PM
For the life of me, I cannot figure out how to attach the original (old) style wiper blades to the arms. Would someone mind explaining or better yet, posting a photo. Or, am I better off simply buying a '54 setup (arms and blades)?
Ok, crickets. So, I tried again and came up with this. Does it look correct? I had to bend out the tabs at the end of the arm fitting in order to make the wiper blade metal portion fit within the fitting. If you think it is wrong, school me on the proper way to do it. Thanks.
If it works, go with it.
