1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 14 Junior Member | | Junior Member Joined: Jan 2006 Posts: 14 | Have a 1949 chevy pickup. The heater switch was out when I got the truck, there are 3 wires coming from the heater, a yellow and 2 orange.Could someone give me some info on how to hook these up? The truck is converted to 12 volt.
Jim Geurts
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Most of the standard heaters have one wire for power. Some replacement motors have two wires to handle positive or negative ground. Take a trickle charger and test it to see what each wire is for. Maybe there is an extra winding to create two speeds. | | |
