5 members (WICruiser, carbking, tesa, D B Cooper, 1 invisible), 86 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
Page 2 of 2 1 2
Remove your Governor and make sure it is working. I had one where the pin on the shaft broke and the gear just turned in place.
To test the governor secure it in a vise and insert the shaft in a drill motor. Hook up an ohm meter, one wire to the contact and the other to ground. Spin it up and it should peg the meter. If not its not working.
Fred
If all the wiring wrings out, take the governor off, remove the end plate and clean the contacts. Then be sure it is well supported, like in a vice, when you chuck it up in a drill motor and spin it up with ohm meter leads attached. (One lead to the terminal, the other to the governor body.) Spinning should give you continuity.
Page 2 of 2 1 2
