3 members (50Chevy3100, 3800GUY, 1 invisible),
180
Mod | | | Forums66 Topics128,110 Posts1,056,255 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Is it safe to assume a 1946 1/2 ton truck never had wide walls from the factory? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Stayed up past your bed time last night Gene? A little sleepy on the keys? I assume you meant white walls? If so, no, the dealer would have put them on for the customer.
DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Ha Ha Yes sir that would be White. Off to work...No not on the truck. I am leaning toward radial Black walls. | | |
