3 members (TUTS 59, greenie-reddy, Youngin' Tut 59), 56 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
#980005 10/20/2013 11:58 PM
Working on my 53 chevy half ton with rear end from a 57 and am ready to get new parking brake cables. My question is will the 53 cables work with the 57 rear end. Just don't want to have to order cables twice.
Ok, maybe i didn't ask the question right. What are u guys using for ebrake cables when u switch to an open drive line. Can u still use the factory ebrake cable.
I think the brake parts are the same. The '53 cables should hook to the '57 arms. Why not pop the drums and have a look?
The brakes are the same. I was just wondering about the length and brakets.
Ok, back on the e-brakes for my 53. The backing plate is different for a 57 which is what i have. The 53 had brakets that bolted on the backing plate the 57 has a whole for that clip to hold them in. What are you guys with open driveline using for ebrake cables.
Is it to late for you to use your 53 axle housing?
The 57 center section will fit right in.
My Blog
yes, too late.
I'm told lokar has some that will fit. I'm going to order them and i'll let you guys know how it works out.
