1 members (Peggy M),
121
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 16 New Guy | | New Guy Joined: Feb 2014 Posts: 16 | My original motor in my 1963 C10 cracked on me so I went on the hunt for a replacement. I found a 1983 chevy inline 6 (230 or 250) which is the same size as the one that cracked. The 83 was TBI so I swapped my head from the 63' onto the new 83' and it fired right up for me.
However, the problem I'm having is after I let the engine get warm I can't seem to get the carb adjusted to give the engine enough gas to idle. Even after it warms up to operating temp I have to stay on the throttle to keep it going. I've opened the idler screw as much as possible and played with the choke and nothing seems to work.
I was curious if the fact that the block portion of the engine (pistons, crank, cam, etc.) used to be TBI has anything to do with this problem. I've thought about upgrading the jets in the carb or possibly spending a little extra money to get an adapter to fit a 2 barrel carb since I have one laying around. Any input, opinions, or advise will be much appreciated.
-Caleb | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Could just need a carb rebuild.Check to see you might have a vac leak also.
Pete
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is a vacuum leak or the float level is low. Like Pete says, put a kit in the carb. I don't know what carb you are using but those one barrel carbs are easy to o-haul. The model B carb has a small plug in the end of the fuel rail in the top part of the carb. If this plug gets blown out of there it won't run at all at slow speeds. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2014 Posts: 16 New Guy | | New Guy Joined: Feb 2014 Posts: 16 | It's a Rochester carb. Thanks guys for the help.
Caleb | | |
