3 members (2-Ton, Mike B, 1 invisible),
69
Mod | | | Forums66 Topics128,030 Posts1,055,419 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | What is the difference in mounting a '56 grill versus a '57 grill? Do you need different upper and lower grill panel bars?? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the openings are the same but the 55-6 grill mounts inside the opening, the 57 grill laps on top of the opening surrounding ridge, the difference is there's holes on the face of the opening for 57, with a 'dimple' flat area around them .... if you put a 56 grill in a 57 you'll have to fill the holes, if a 57 grill in a 56, you'll have to make the holes .... note the holes each side of the 56 grill in a 57 truck - the 57 grill back inBill | | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | I have a 57 truck. I want to buy a 56 chrome grill as 57 are way too high and I like the look of the 56 anyway. The lower grill panel bar is bent to a point where a new one is needed. The catalog lists a 55-56 or a 57. If using a 56 grill on a 57 truck, should one order a 55-56 lower panel bar? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, they fit the same in the opening but the 57 one is designed for mounting the 57 grill so you'd need to modify mounting holes for the 56 grill
Bill | | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | The 57 front fender are indented for the 57 grill bracket. For resale etc no matter cost the proper grill is better. The cost of dealing with either replacing or filling and painting the front fenders out weighs the grill cost easy. Just remember the 57 is a one of a kind front fender slash grill assembly truck, and if the fenders are rust free in filling the holes and dents you would be ruining some good original fenders.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
