7 members (Cosmo, Shaffer's1950, Oswald, Wally / Montana, J Lucas, 2 invisible), 47 guests, and 1 robot.
Topics128,075
Posts1,055,918
Members48,429
#1010368 02/28/2014 12:56 AM
I pulled the water pump off of my 270 and sent it off to be rebuilt. I'm finishing a rebuild on the engine and had the pump rebuilt to be safe. When I got it back it spun like a new pump. When I installed it last night I found that it was hard to turn by hand. The pump turns freer the more I back out the mounting bolts.
This is the original pump off the engine and is installed with new gaskets. It seems to be binding. What gives? What am I missing?
It sounds like the shaft is hitting the back plate.
In some cases I have to grind the end of the shaft slightly.
My Blog
Dave, that was it. I destroyed my gaskets and had to grind about 3/32s off, but it's good now. Thanks! smile
