1 members (baldeagle),
107
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 12 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 12 | Is there a secret to running wires through this loom?It seems the harder I try to pull the wire bundle thru the loom the tighter it gets.If anyone has any tips they can give me it sure would be appreciated. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Use two people to pull it tight, do it before you mount the wire on the truck, and use a coathanger taped to the end of the wire and pull the coat hanger thru first. It sucks but that is the only way I could get it done. I couldn't do it by myself... Good luck! | | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | Standonit,
I've never used the cloth wire loom, but the stuff we use at work is just like it ( just made of plastic). It acts like a chinese finger trap, the more you pull the loom the tighter it gets.
If you push the loom over the wire it seem to work better than trying to pull the wire through the loom. If it gets tight try compressing the loom together, it should expand and allow the wire to move freely.
Hope that helps more that it confuses.
Gary, Kelly, and Family
| | | | | Joined: May 2005 Posts: 12 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 12 | Thanks for all the help guys.I am going to try and get the tailight harness thru the loom this evening when I get home.Thanks Again,Mike. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Did you get it thru the loom? BTW: I never knew there was a lubricant for cloth loom... I learn more everyday! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | virginiafiretruck,
I think I misinformed Mike....while I pull wire occasionally through conduit and do use a wire pulling lube, I don't think this item was primarily meant for a cloth loom. I think CenTex had the right idea on the 'finger trap' scenario.
Stuart | | |
