5 members (78buckshot, 49oneton, Napco Man, Otto Skorzeny, tclederman), 121 guests, and 2 robots.
Topics128,115
Posts1,056,623
Members48,450
I'm in reassembly stage and want to confirm that the core support is fastened on each side with hardware in the following order: Bolt passes through split washer, shim, cushion, SPACER and core support, cushion, then a second shim?
Also - I can't find new spacers anywhere....I assume they are necessary....what have others done to replace?
gobolt
Bump - really need help on this...can someone verify that I have the order correct? Obviously makes a difference on everything lining up....anyone with a 58 or 59 1/2 ton??
gobolt
I'm not sure exactly what the question is, but if you need a shim I think it would be to raise the whole core so no need for one underneath, and the split/lock washer would go on just before the nut. Next to last.
I'd use a large washer for the head of the bolt to ride on(if it fits) instead of the split one 'second'.
Body shim/spacers are @ the FLAPS.
In the end expect to put it together and take it apart several times at least before 'things line up'.
I found some things reveal themselves after the 3rd or 4th time of fitting them all together and blowing them back apart looking for an extra 1/32 clearance.
Give me ambiguity
or give me something else
Thanks - I appreciate the help...it is now together (3rd try, as you suggested it might take!)
gobolt
