1 members (Eisenholtz),
59
Mod | | | Forums66 Topics128,022 Posts1,055,377 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | I am finishing my '50 3100 resto and have a question on the headlight/parklight wiring. Specifically how to route the the passenger side wiring from the left junction bar (on the inner fender) to the right. I have clips in a ziplock with 'upper radiator panel headlight wiring clips', but I do not remember where they went. Assembly manual is not clear. I believe the wiring goes through the gap between the inner fender and the radiator support and goes across the radiator behind the grill. And I right and where is it routed and attached in that area? Thanks in advance for any help. Steve O | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Nifty50, All the AD trucks Ive seen And mine also, have the wires going up and over the radiator support and those clips you have go under the upper radiator baffle bolts,right across the top in front of the rad. Regards Steve Sr. | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Steve Sr. Thanks, but I think I still need a little clarification. If the truck was assembled, you would not see the wires? That is to say the upper baffle/hood latch plate would cover them. And if you took the baffle/plate off, the wiring would be right there underneath with the clips in the upper uprights of the U shaped radiator support frame. Do I have this right? Thanks again Steve O | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Steve O, If the truck was assembled, the wires run right across,ON TOP of the baffle and are secured by those 4 clips and bolts right next to the top rad support brace. Regards, Steve Sr. | | |
