I'm in reassembly stage and want to confirm that the core support is fastened on each side with hardware in the following order: Bolt passes through split washer, shim, cushion, SPACER and core support, cushion, then a second shim?
Also - I can't find new spacers anywhere....I assume they are necessary....what have others done to replace?
