5 members (Hanks custodian, Phak1, Lostbuthaulinass, homer52, Wheelie), 138 guests, and 3 robots.
Topics128,042
Posts1,055,519
Members48,424
#1011356 03/03/2014 7:28 PM
I cut the line to the oil pressure sensor, not thinking that it would leak...
I want to add a new (modern) oil pressure sensor to my 235 engine block.
What options do I have?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
One option is to add a compression "T". That way you can use the old gauge and a new one if you like. Same fittings as the "new" plastic line would use. Check with your local FLAPS.
The other option would be a compression union to mate the new gauge to the old line. Only one gauge that way. I hope that is helpful. FYI: that little tiny oil line will let a LOT of oil out real fast so make sure the connections don't leak.
Steve H
I have what I think Steve is describing. An oil unit out on the block as well as inside. It is screwed right into a brass T.
Good Luck
36 Chevy 1.5 ton - rusting away
52 Chevy 3100 - in progress
72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
Sir Searchalot
Sir Searchalot
If you mean add, you need the "T". If you mean replace with a new modern one, and you don't care if it fits into gauge cluster, get an electrical set. Gauge and sender and wire. Install sender in old port area and Install gauge in some neat place. No leaky.
Can you show me a pic of this "T"?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
Sir Searchalot
Sir Searchalot
A "T" is a fitting for plumbing. Shape of a "T", three ports for attaching three tubes/pipes, same as PVC fitting only brass and small. Threaded for what ever you are attaching. Flare, compression, pipe, etc. There are elbows (els), couplings, Tee's... for all plumbing types. See the internet for pics.
Looks like this:
http://www.speedograph-richfield.com/html/oil_pipe_lines.html
You can run more than one gauge. You can run one electric and one "hydraulic", or any combination you would like.
Steve H
Sorry guys I do not have a flicker account so no photos at this time. Steve's got it though. Just screw the manual gauge direct into the end of the T in his photo so you can read pressure outside the cab. Run the other line into the cab.
Good luck
72 Chevy K20 - DD
Stupid question, would a oil pressure switch with 3/8 in. x 18 NPT thread size work on my 1954 235 straight 6?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
I don't think so.
72 Chevy K20 - DD
