| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I Have been trying to get my hood strips on my 46 clean and polished. I was watching American Restoration on HGTV and Rick had a segment on removing rust pimples from chrome using aluminum foil. So I tried my same metal polish with the aluminum foil and it took off the years of grime. Then repeated with a rag and they shine like new. Now time to paint the red stripe in the middle  . | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Interesting! I've got that task on the list too. How is the foil used? Instead of the microfiber towel with polish? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Yes just like cloth. Bunch it up and rub. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's an old trick that I was taught by the porters to clean up rusty bumpers on the used car trade-in's when I first started working at Phil O'Keefe Chevrolet back in the late 50's. Here are a couple of original chrome plated hub caps for a '50, 3600 that were badly pitted and rust stained when I got the truck back in '05. The reproduction hubcaps won't clear the free floating hubs on the rear so I had to use the original ones. These four pictures was taken just this morning. I hadn't cleaned them for quite a while, years in fact, and you can see the pits are quite pronounced. A quick rub with a wade of foil and from a couple of feet away the rust pits almost disappear, They will look even better after a wax is applied: http://www.pbase.com/dennygraham/image/154683852Click 'next' in the upper right corner to see each one. I think what happens is the aluminum is much softer than the chrome so it won't scratch it but it is abrasive to the stains. I also think it leaves a little of the aluminum in the pits that helps to hide them.
Denny G Sandwich, IL
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | What brand metal polish is recommended? Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What brand metal polish is recommended? Harold For chrome or for stainless steel? Happich Simichrome Polish Autosol Metal Polish Bar Keepers Friend | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not trying to steal your thread GW just throwing out my opinions to the discussion. Any of the commercial chrome cleaners would work just fine for cleaning chrome. I use Borden's No.7 Chrome Polish, which I got at Farm & Fleet and I've literally had it for decades and have no idea if they still make it: http://www.pbase.com/dennygraham/image/154684224/largeI'm sure Gene has his favorite also as most everyone here does. What ever you do, don't use a Scotch Bright pad on any chrome plated part unless you're planning on painting it afterword's. DG
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Thank you, thank you, thank you. Just bought a used pickup with rusty nerf bars--1/4" to 1/2" rust circles raised above the circles. My metal polish was doing nothing. However, Wenol and aluminum foil erased most of the rust and significantly improved the appearance. It's always great signing onto the 'Bolt. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I can't take credit for this one - good old TV Ricks Restoration. What I am using is Blue Magic Metal Polish Cream. It works on all sorts of stuff. The reality is you can always sand down to 2000 grit and with enough different abrasives you can bring it to a mirror shine assuming you have enough metal. Just thought I'd share as it was new to me. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Hey Denny, who's that distorted looking fellow trapped inside that there hubcap? Carl
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Different Subject Denny. What do you do with the center hubs of wheels. Do you assemble the hubs to the rims? like with rivets or weld them? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | He's the distorted one that's connected to the distorted one that's addicted to this here web page.
That's a project in the works Gene. I've just got the centers punched out, haven't yet been able to find rims with a 14.25" ID to put them in. If I could find a 16" or 17" ID rim blank that would accept them I would plug weld the centers to them. All of the vendors that are making rims cut the flanges off and weld the centers to the rim from the back side only. Not my favorite way of installing them. Posted a bunch on that subject in another thread.
Denny G
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I can't take credit for this one - good old TV Ricks Restoration. What I am using is Blue Magic Metal Polish Cream. It works on all sorts of stuff. The reality is you can always sand down to 2000 grit and with enough different abrasives you can bring it to a mirror shine assuming you have enough metal. Just thought I'd share as it was new to me. Gene, can you post some pictures of your results please? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I am painting the red stripe Saturday and after that sure. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have my stainless Hood Strips in photo bucket. The other new photo's are for a roller system I made for the door windows and track. I had used cintered brass bushings and they broke so I had some new rollers made from hard brass. Once I got the regulator springs fixed the windows operate great and stay up. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Thanks, the stainless looks awesome! | | |
