Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Steelonsteel, TUTS 59), 41 guests, and 8 robots.
Topics128,010
Posts1,055,299
Members48,419
#101100 06/09/2007 6:15 PM
Drove home thursday from work...ran inside the house came back out truck would not start....I thought it was the starter...So I had it rebuilt...put it back in and its making the same noise.....Its a foot starter...It engages the flywheel but just makes a buzzing sound...when you push on the buttom its spins..you can here the gear spinning...but when it engages the flywheel...it sounds like the shaft is beginning....Any body have answer....51
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
#101101 06/09/2007 6:23 PM
You could have some damaged flywheel teeth and it just happens to be sitting on the bad spot. Try rotating the engine with the fan blade then try the starter again.
#101102 06/09/2007 6:50 PM
Holcomb,
Your starter has a over-running clutch enclosed in the starter drive. Some call it a roller clutch. It is suppose to lock up in one direction and allow the starter motor to spin the engine. As the engine starts and over speeds the drive, the over-running clutch allows rotation as the starter drive is thrown back into the starter. I will guess that when this fails it goes buzzzzz!
I wonder why this wasn't checked when the starter was rebuilt...maybe it offers enough resistance by hand, but not when blasted by the starter motor.
Stuart
#101103 06/09/2007 10:30 PM
Thanks guys.....I had ordered a starter from kragen...wasn't suppose to be here until Monday but it came in this afternoon...bolted it in truck fired right up...SO that means they didn't rebuild the starter correctly...I believe the rolling clutch stuff was not none...so no more buzzing sound....thanks again guys for your answer..
1951 3100
Pablo Picasso
