Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (Charles in CA, JW51, Brewhog55, 1 invisible), 562 guests, and 1 robot.
Topics126,781
Posts1,039,301
Members48,100
Most Online2,175
Jul 21st, 2025
What is the best and cheapest way to get about 10 to 15 more miles per hour out of my 1 ton. Truck is completely stock.
Taller tires or only driving down hill. smile
as Carl indicates Randy, there really isn't a 'cheap' way, only pretty spendy rear end change or even more spendy aftermarket overdrive
The easiest way is to find a guy that is swapping out a 3600 3/4 ton rearend. You could probably get them for free or little money. The 4.57's from the 3600 trucks will drop your RPM's about 250-300 depending on your tire size. Another option, which is harder to come by, is a 4.10 gearset from a 67-72 1 ton truck. They'll drop your RPM another 200-250 RPM.
The next option is an overdrive transmission.
Whatever you do, make sure your engine is up to snuff. A good tune up and carb rebuild will go a long way.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Crusing in the Passing Lane
GM 14 bolt axles are cheap and plentiful, 8 lug, usually $150., lots of ratios.
OVERDRIVE TRANSMISSION SWAP, taller tires, and better gearing.
There are many OD transmissions to choose from including but not limited to the T5, NV4500, A833/my6, roadranger OD, Gear Venders OD, etc. Most OD transmissions drop rpm at cruising speed by 27%. Many are direct bolt in swaps, however most will require the driveshaft to be modified.
Usally I would reccomend a transmission more stout than a t5 for a 1 ton truck,however if you have a stock 216 or 235, I don't believe it would hurt the transmission. Weight would be the enemy more than HP or torque.
If you have 17" or 18" tires and put a 4.57 rear out of a 3/4 ton, it will run 60 all day long, You probably don't have brakes that are suitable for much faster than that. I used to drive 70 all day long with a GMC with 4.57 and 7.50x17 tires. You just need to step on the gas a little harder and get used to the noise.
Stock t5 is rated for 300 lb/ft
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.033s Queries: 14 (0.030s) Memory: 0.6260 MB (Peak: 0.6970 MB) Data Comp: Zlib Server Time: 2025-09-22 22:35:58 UTC
Valid HTML 5 and Valid CSS
