1 members (NJC),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | After putting in a new sending unit, AND new gauge for the '53 bolt, the gauge only reads half full even though the tank is full. Are there any quick tests to see what might be wrong? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Shmoo,
Usually a problem gauge will show full all the time or empty all the time. To read properly up to half is strange. To prove the gauge, go to the sending unit wire at the tank and pull it off. With the key ON your gauge should swing to FULL. Take that same wire and ground it to a good clean ground on the body or tank. Again, with the key ON the gauge should now swing to EMPTY.
If all this happened, your gauge is good and so are the wires associated with the gauge. This means the sending unit is at fault or that the tank might not be grounded well. It will be interesting to hear your results as your system seems to be working properly...but as you stated, pessimistically! Keep us posted.
Stuart | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | 30 Ohm sending unit with 90 Ohm gauge or no ground to the case of the gauge, maybe. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Shmoo, Baldy's post turned on a light in my old dark brain. I looked at your previous posts and lo and behold, this fuel tank deal has a rap sheet as long as my arm. There is some 12 volt stuff in the mix too so there might be more to this than meets the casual eye. Stuart | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I got so P.....off at my new sender..and guage,that i am just going to top it off when ever i go by a gas station...and carry a gas can...went thru 2 senders...followed instructions...4 days of scratching my head and staring at it with beer ....I have taken my new Bezel off so many times....I think I have stretched out the oil guage line.One time I forgot to hook up the oil pressure line and had oil squirt in my new Lens. Then I went to clean the new lense and I scratched it using paper towels..Had to order a new one..I could go on about the gas guage..But I wont...it makes me drink to much beer
HURRY UP AND WAIT 55 235 3/4
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by Mike G.: I could go on about the gas guage..But I wont...it makes me drink too much beer :hammering:
