| | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | does anyone have a diagram for the turnsignal switch on a taskforce truck? thanks guys | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Check out the Tech Tip that I wrote. I forgot to mention, it's the same as the '54. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I have a copy of wiring diagram for the dealer add on turn signal ,,its for the "guide" set up that went on the '54s and '55 first series. its for the one that actually belongs there,,not the "yankee" or "turnco" aftermarkets. If youd like to give it a try,,i'll send you a copy. P.M. me with your address and its in the mail to ya. Marty | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | here's the dealer accessory procedure if you have all the right pieces including the harness - wiring diagram on the last page Bill | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I followed Cletis' instructions (along with a couple of emails) and my signals have been working for more than a year. Can't thank him enough.
"Happiness equals reality minus expectations" - Tom Magliozzi
