3 members (DoubleB, Phak1, tclederman), 43 guests, and 1 robot.
Topics128,091
Posts1,056,033
Members48,433
#1008910 02/21/2014 10:51 PM
rwb
Offline
I took off fuel pump 1959 235 while prepping engine
anyway one of the bolts that holds it on
is drilled hollow and hose barb on end that has hose
to fuel pump.the fuel pump double type.
this engine came out of a 1 1/2 ton. i didnt
notice where the other side went on that truck.??
or what it was for.engine oil is in that part of pump.
can i just not use that part and put reg bolt back in.
what was its purpose ??
thanks
rwb #1009293 02/23/2014 8:15 PM
It was probably used as an oil filter return line. On certain GMC 270s that's what they are used for. Its a quick and easy way to return oil to the pan without drilling the block.
rwb #1009298 02/23/2014 8:35 PM
Just put a regular bolt in it.
