| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | I am finally having to deal with the terrible wiring in my truck, after nearly setting it afire. Aparrently the rew wire to the long dead ammeter shorted to the windshield wiper arm and melted a lot of stuff. I have pretty much cleaned up all the wiring replacing the extra crispy one. In the ordeal I pulled the ignition switch, now I can't figure out how it wires back up. It does NOT match the terminal lay out in the factory wiring diagram. I have 7 terminals, a "BAT", 2 "IGN", 2 "ACC", 1 "ST", and a blank. I have 1 black wire to the starter, 1 red wire to the light switch/regulator?, 1 pair of green wires to the coil and starter (on the same terminal), 1 pink wire to the turn signals, 1 brown wire (forgot where it goes) Any ways, any one can tell me what goes where? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | here are two from aprevious post that might help click here click here are you going to the small town event/cruise/show that is being held in El-reno this coming week-end.. we will be going. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | I ended up guessing it right, on the third try.
Thanks. | | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | What's going on in El Reno? June 2nd? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | blazer - here\'s the early style sw - the later one has a slightly different look , but the wires are the same - you may not have some wires, but the critical ones should be the same if you have the correct original color wires .... the different colored wires to the ign resistor are to opposite ends - the 2 green should go to the coil so it gets power either from the resistor or the starter bypass .... I think I got that right! Bill | | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | Mine didn't look like either one of those.
I'll post a pic in a few minutes maybe tomorrow, maybe.
I was just about to check the events forum. Haven't gotten to take the old truck anywhere... | | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | Heres a picture of mine. Ignition back | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | replacement item, and from the look of the plastic, a new [correct] switch may be called for the way to tell what would go where is to check the function of the switch with a meter, pretty straight forward with the foot start Bill | | |
