1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
#1009083 02/22/2014 6:38 PM
My 1960 c40 windshield washers just pitter out fluid. Is this a common occurrence when the pump gets weak or is there some else a miss? Also the pump I assume is up under the dash? Thanks
1953 Chevrolet Handyman Wagon 36k
1938 Buick 38k
1947 Hudson Commodore 18k
Windshield washer system, wasn't standandard equipment, until 1966 on trucks, so it is hard to say what equipment your truck has and what may be causing the low fluid pressure. The pump is typically mounted on the wiper motor & is activated, when the wipers are switched on. The wiper motor has a cam on the drive shaft, that activates the pump. A number of things can cause little or no fluid pressure, including low fluid level, missing or dislodged pick-up tube in the reservoir, compromised fluid lines, faulty diaphram in the pump or lower motor rpm's. take a closer look at the system and the components, lines & wiring, to be sure everything is in good working order
