5 members (78buckshot, baldeagle, ShopRag, J Lucas, Wally / Montana), 73 guests, and 6 robots.
Topics128,020
Posts1,055,345
Members48,420
#1007780 02/17/2014 2:43 AM
With all the weld in components available out there, has anyone just built their own frame with 2X4 Tubing? Would love to hear any thoughts on this.
morepower16 #1007838 02/17/2014 9:17 AM
Being done every day. We usually plasma cut the sides out of 11 gauge cold rolled flat stock and then mig weld the top and bottom 2" flat strap to the sides. This gives the deep center section and tapered front and rear ends much like the factory frames. One can also contour the side rails to fit the floor pan profile if it has been modified. An advantage over the tubing, other than looks, is that one can mark and drill the top strap, then weld on the "weld nuts" the same as the factory did on the original "C" channel frame. On tube frames many use Riv-Nuts. It is best to have a rigid table or jig to keep everything true. Using an "X" member or at least a "K" member will give a much stronger frame than the straight ladder type. That being said, we have done many with tubing which gives a smooth surface without hours of grinding and with a little planning can give nice suspension mount points for such things as ladder/four link mounts, Panard bars, etc. If you weld in anti-collapse tubes and use bolts that pass through both sides of the frame for the various components it's bukoo strong.
Evan
morepower16 #1008384 02/19/2014 4:18 PM
There are tons and tons like this, but you're unlikely to find them here. There are lots on Hot Rod sites.
My 46 GMC on Photobucket
morepower16 #1008422 02/19/2014 7:07 PM
Try here
http://67-72chevytrucks.com/vboard/showthread.php?t=606275
Considering the cost of an Art Morrison or TCI chassis, DIY is a no brainer if you have the tools and time.
Do youself a favor and buy a build sheet for the AD trucks. It'll give you the specs you need.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
