BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
1 members (Danielbolt),
487
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,267 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Feb 2014 Posts: 5 New Guy | New Guy Joined: Feb 2014 Posts: 5 | So I have a used to be running '59 GMC 100 V-8. It has the short bed too. Here are some pics... 59 GMC 1 59 GMC 2 59 GMC 3 59 GMC 4 59 GMC 5 59 GMC 1 It ran when I parked it 12+ years ago, but has sat since then. Would like to temporarily start it so I can move it out of it's current spot. Engine oil looks good, no water or anything odd. Should I turn the engine over for say 30 seconds to get the oil pressurized.? Any other tips I could use would be gladly accepted. | | | | Joined: Nov 1995 Posts: 5,470 Bond Villain | Bond Villain Joined: Nov 1995 Posts: 5,470 | Welcome to Stovebolt.com, InsulatorKing! Do you collect insulators or is that a vocational thing? Anyhow, you're in luck! Our crew got together and wrote a pretty comprehensive tech tip on just this sort of thing -- How to bring a dead/sleeping engine back to life Pretty much all you need to know should be in there. Let us know (in this thread) how it goes or if you have any issues. Again, welcome! Tell us more about your truck! John
~ John "We are not now that strength which in old days Moved earth and heaven; that which we are, we are" 1948 International Farmall Super A1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump2001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | Joined: Feb 2014 Posts: 5 New Guy | New Guy Joined: Feb 2014 Posts: 5 | Hi John,
Yes, I collected insulators, but am no longer actively accumulating them.
I bought it in Nevada, and moved a bunch of stuff from there to New Mexico. Used it quite a bit for various hauling, etc.
Gave it to my daughter and she was going to fix it up, but she got married and had a baby, she gave it back to me. Now I have to figure out what to do w/ it myself. | | | | Joined: Nov 1995 Posts: 5,470 Bond Villain | Bond Villain Joined: Nov 1995 Posts: 5,470 | It looks like a beautifully solid truck. I bet it won't take much to get her started -- you should be able to move through the steps in the article pretty quickly. A lot of it may seem anal, but we like to be methodical around here. We don't want anything unfortunate to happen to either you or the truck. That was cool of your daughter to give it back. As for figuring out what to do with it .... We'll all be glad to help with that! First thing is to get ti running (and stopping  ) and just drive it for awhile as is -- it looks solid enough to be a driver the way it is so have some fun with it. It will come to you in good time what you should do with it. John
~ John "We are not now that strength which in old days Moved earth and heaven; that which we are, we are" 1948 International Farmall Super A1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump2001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | Joined: Feb 2014 Posts: 5 New Guy | New Guy Joined: Feb 2014 Posts: 5 | A little more info about this truck.
Serial No. 101 8 C S 5xxxA 101 8 = 114" wheelbase w/ 336 V8 engine C = Conventional S= 1959 A = Rear susp Spicer 45 Clutch is 11" as well.
Info above is According to oldGMCTruck.com . Very helpful in discovering what stuff means.
| | | | Joined: Apr 2010 Posts: 362 Shop Shark | Shop Shark Joined: Apr 2010 Posts: 362 | Wow. I wish my 58 GMC was in that good of a shape. You're a lucky man and if it were me I'd be driving that truck tomorrow. Anyway good luck and I hope you keep it or send it to a fellow bolter to enjoy.Larry
58 gmc 100 with 350 sbc
| | | | Joined: Apr 2010 Posts: 232 'Bolter | 'Bolter Joined: Apr 2010 Posts: 232 | Love to see the Pontiac/GMC v8 in the 50's Jimmies. That's a great survivor. What transmission is mounted behind that?
| | | | Joined: Feb 2014 Posts: 5 New Guy | New Guy Joined: Feb 2014 Posts: 5 | Thanks.
It has the 4 speed on the floor. Gears are L [Low or Granny], 1, 2, 3. | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | 'Bolter Joined: Jan 2013 Posts: 1,518 | Amazing truck to see, made my day. Like one said a great survivor with a Pontiac engine too. Ya best keep it. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | Joined: Apr 2014 Posts: 51 'Bolter | 'Bolter Joined: Apr 2014 Posts: 51 | I would definitely change the oil if its 12 years old
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 9 years) 1966 Chevelle (owned 50 years) 1965 Corvette (owned 34 years)
