5 members (TexasJim50, Peggy M, Woodcmiami, MickeyP, Hanks custodian), 83 guests, and 2 robots.
Topics128,059
Posts1,055,818
#100810 05/18/2007 6:52 PM
I am modernizing a '47 1/2, and a '48 panel. Does anyone know of a multi speed 12v heater motor? The original 6v motor uses a resistor in the switch for two speeds, high and low. With my 12v system that's high and blastoff. The resistor burned up. I used a rheostat for awhile, but it got so hot the plastic knob melted. Now I am ready to replace the 6v motor with a 12v. Napa has a 12v motor that will go right in, but it is only one speed. Similar to the American Classic part. American Classic also has the rheostat for speed control. Is the rheostat the way to go for heater motor speed control, or is there a multi-speed motor available? A multi-tapped motor. 5/16" shaft, 3 1/4" case, 2 studs 2" on center.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
#100811 05/18/2007 7:10 PM
any motor is one speed, you just need to get the variable resistor sw for 12V, which works fine - NAPA should have them or one of the vendors have them like this
#100812 05/18/2007 7:14 PM
I used a Comfort Temp part number 35576 motor and cut the shaft to length.This is a 12 volt reversible motor(PM motor).I used an orignal style two speed switch that clamps under the dash.It works well.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#100813 05/19/2007 8:17 PM
I see now, I have checked three shop manuals and they all have the one speed motors with resistor networks for speed control. I liked the potentiometer I had because it was for a variable speed, but I think the multiple position switch type is more robust. I had replaced a fan motor in a window air conditioner that had multiple taps for the different speeds, but that doesn't seem to be an option for automotive.
In Project Journals
In the DITY Gallery
#100814 05/19/2007 8:33 PM
actually Walter, the sw on these ol trucks is a multiple tap ceramic resistor, high, med, low, like this original
#100815 05/20/2007 12:40 AM
I agree with bill !!!
1951 3100 Chevrolet
#100816 05/20/2007 2:52 AM
Yup, I burned mine up, replaced it with an aftermarket rheostat, the one with the lighted plasic knob. Melted the knob. Now I will get a 12 volt motor, and one of those three position switches so it will look stock.
In Project Journals
In the DITY Gallery
#100817 05/21/2007 10:49 PM
Even the BMW I used to have had a multi-tap resistor for blower speed instead of a multi-wound motor. Its very common.
Paint & Body Shop moderator
