1 members (RLB), 116 guests, and 2 robots.
Topics128,090
Posts1,056,378
Members48,442
What is the correct thermostat for (1946) 216 engine?
Any suggestions as to brand name ?
Thanks.
Harold
Harold
Depending on how much heat you want the heater to produce, go with a 160 or a 180 degree stat. Brand name isn't really important, as virtually everything these days is made in some 3rd. world country, no matter whose name they slap on the box! Drill a 1/8" hole in the flat part of the thermostat if it doesn't have a vent hole already- - - -it makes it much easier to fill the radiator when the engine is cold.
A stat with higher than a 180 rating isn't appropriate foe low pressure or no-pressure cooling systems- - -too much risk of getting more pressure than the radiator and heater corer can stand.
Jerry.
Thanks for your response.
Harold
Harold
V
V Offline
I ran a 160 all last spring,summer & fall with out any problems. Temps avg'ed under 180 even on the hottest days.
I went to a 180 come winter for 2 different reasons.
1) To cut down on condensation buildup in the valve cover.
2) I saw an old Jim Handy film on youtube which indicated that these old stovebolts were designed to run at 180 degrees.
The 180 did cut down on the condensation buildup and the temps have been avg'ing right at 180 this winter which gives me real good cab heat.
I've kept the 160 just in case my old 216 runs hot come 90 d+egree summer days.
Dave
What pressure cap do you use with the 180 thermostat?
Same radiator cap works fine with 160 and 180. 0 pressure cap on old radiators(pre-47?) and a low 4-7 for newer say 47 to 58? 15 Lb for 195 to prevent boil over. If you have a good radiator. I have run more modern, say 1967 and up with a 180 no problems, but for systems designed for higher temps, you might run a bit rich, and new stuff has to pass emissions testing, so stick with what the manuf. suggests.
Steve H
