| | | Forums66 Topics128,081 Posts1,056,069 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 9 New Guy | | New Guy Joined: Jun 2009 Posts: 9 | Will 57 hood hinges work on a 58 Apache.
C Loubser
43 Ford CMP 4x4 48 Ford F1 41 CCKW 2 1/2 ton GMC 6x6 57 Land Rover series 1 59 Mercedes 220s
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I don't think so. I've got a 58 and everything I've seen in the catalogues are that they are different. The main cabs are the same so it must be the fact that the hood and fenders are different, wider at the top for the 4 headlights.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not interchangeable - the 55-57 hinges [ 57 hinge pic] mount to the firewall only - the 58/9 hinges [ 58 hinge pic] bolt to the firewall and the inner fender as well, and each bolts to the hood differently - PLUS the spring for 57 mounts entirely on the hinge, the 58 spring mounts from the hinge to the inner fender Bill | | |
