2 members (Gray_Ghost, BC59), 173 guests, and 2 robots.
Topics128,079
Posts1,056,058
Members48,433
#1006793 02/13/2014 11:28 AM
Will 57 hood hinges work on a 58 Apache.
C Loubser
43 Ford CMP 4x4
48 Ford F1
41 CCKW 2 1/2 ton GMC 6x6
57 Land Rover series 1
59 Mercedes 220s
CHEVNAM #1006819 02/13/2014 3:32 PM
I don't think so. I've got a 58 and everything I've seen in the catalogues are that they are different. The main cabs are the same so it must be the fact that the hood and fenders are different, wider at the top for the 4 headlights.Larry
58 gmc 100 with 350 sbc
CHEVNAM #1006843 02/13/2014 4:50 PM
not interchangeable - the 55-57 hinges [57 hinge pic] mount to the firewall only - the 58/9 hinges [58 hinge pic] bolt to the firewall and the inner fender as well, and each bolts to the hood differently - PLUS the spring for 57 mounts entirely on the hinge, the 58 spring mounts from the hinge to the inner fender
