2 members (dt235sd, crenwelge),
127
Mod | | | Forums66 Topics128,290 Posts1,058,557 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Over the weekend I scored a pair of very nice "Tripp" running lights for my Packard. It has a 6 volt bulb #1105S. Does anyone know what the 12 volt version of this bulb is? Is there a converstion chart somewhere? Thanks
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | I can't find that number in my catalogs. If it is a sealed beam type you can take one as a sample and visually compare.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | It is not a sealed beam. It is a bulb like a 1157. It does look like a high current bulb as it's "face" is painted black. Thanks
| | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | take the org bulb to a parts store and tell them what you want to do...doc | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Found the conversion. It crosses over to a #1195, which is a back up light for a '68 Rivera. NAPA has it wrong but that's what it is. Thanks for the help.
