8 members (Hotrod Lincoln, tclederman, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny),
182
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I've been going through the wiring on the truck and replacing most of it. Between a basic wiring schematic that I believe I got from somone on this board a year or two ago and the microscopic one in the shop manual, I believe I have most of the wiring sorted out and correct (we'll see after I hook everything up, put the gauge cluster back in, and try starting it I guess  ). However, neither diagram shows how the blower motor on the heater should be wired in. Right now, it is supplied through what appears to be 14 gauge wire from the battery terminal on the starter motor to the heater switch and from there to the blower motor with a second wire from the blower motor to ground. Is this correct? Can anybody confirm what the correct wiring is for a blower motor on a 58? If it matters, it is the original recirc heater not the deluxe heater.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | On my 59 GMC, the wiring is like this: 1. Big red battery wire to starter lug 2. 14g wire from starter lug to key switch 3. 14g pink wire from ACC on key switch to fuse block 4. Glass fuse for heater 5. 14g wire over to heater switch ...
That's where my wiring "harness" stops. The previous owner dismantled the heater stuff for some reason. <shrug>
But, there should also be a NiChrome wire on ceramic system close to or on the fan speed selection switch. It acts like two or three resistors so you can alter the fan speed.
I know I had one on my 58 'cause I burned my hand on it at least once.
Otherwise, you're on track. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I have a recirc type, but I think it too is just as Ezekiel said, only there is also a brown wire that goes from my switch to the blower. That NiChrome ceramic thingamabob/resistor is between the red wire and the brown wire. From memory. No warranty expressed or implied! Bill | | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | My 57 is just as Ezekiel says, but I have no ceramics or resistors. My heater switch is just a three-position (three fan speeds) switch. | | |
