0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 48 | I just got my truck and the rear upper shock mounts are gone. I see where they bolt to the crossmember, but have no idea what they look like and cant find a parts house that can help. Does anybody either have a pair or know of an aftermarket part that would fit. If not, how about a pic of what they look like? I found these, and I think they might work. Thanks, Matt https://westernchassisinc.com/1963-72-Chevy-and-GMC-Truck-Shock-Mount-Kit-Front/
Matt Blacktop Cannibals Car Club 1954 Chevy mild custom car 1955 Chevy second series 3200
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | American Classic Truck Parts U-SMR2155, used $25 and a picture. You can buy two of these, go to a junk yard or make them from bar stock (flat, not jogged, would work) and a shock mount (O'Reilly's 31001 or equiv). They are a very simple piece. The angle is given to you by the holes in cross member. Probably a dozen ways to provide a DIY upper mount. The exact location is not critical. Post in the wanted section, it's always nice to have the actual part if you can find/afford it. The ones you reference may work even though the shock eye would be 90 deg from orig. But you can see how easy it would be to design your own and their price is about the same as two American Classic ones. Two DIY/somebody's bracket, design considerations: 1. Shock eye does not hit bed floor and 2.Shock tube clears rear cross member. Mock it before you lock it!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2014 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 48 | Thank you. I now have a starting point.
