6 members (frogfarmer, pauld, Shaffer's1950, lumbersawyer, BC59, 1 invisible), 185 guests, and 5 robots.
Topics128,264
Posts1,058,358
Members48,485
#100598 05/05/2007 10:24 PM
Hey Guys,
This is a picture of my starter and the wires going to it.
Can anyone tell me what connects to the little stud just below the red battery wire?
Thanks!
PS: The dangley wire in the foreground is an ignition coil wire.
#100599 05/05/2007 10:29 PM
the coil wire goes there, if it's a 12v, and that's the ignition resistor bypass when the starter is engaged, no power otherwise, so the coil + comes thru the ign resistor
#100600 05/05/2007 10:40 PM
Thanks Bill!
#100601 05/09/2007 8:29 PM
I will look at mine when i get home. if that is the original 6V foot stomp starter, i don't think the is a wire connection. But let me check.
"It ain't a truck if you can't hose out the cab."
