0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Hey Guys, This is a picture of my starter and the wires going to it. Can anyone tell me what connects to the little stud just below the red battery wire? Thanks! PS: The dangley wire in the foreground is an ignition coil wire. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the coil wire goes there, if it's a 12v, and that's the ignition resistor bypass when the starter is engaged, no power otherwise, so the coil + comes thru the ign resistor
Bill | | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | I will look at mine when i get home. if that is the original 6V foot stomp starter, i don't think the is a wire connection. But let me check.
"It ain't a truck if you can't hose out the cab."
