4 members (jmoore, Gray_Ghost, 1955 1 Series, Goach2), 85 guests, and 3 robots.
Topics128,194
Posts1,057,264
Members48,466
Does anyone know where to get new dust caps for the front wheel bearing hubs on a '57 3/4 ton? I think that they are the same dust caps for 3/4 and one tons from '47 through '59.
The diameter of the part that goes into the hub measures at 2.305".
I know this sounds like a silly request, but I can't find them anywhere...auto parts places, trailer places, etrailer, etc.
On my internet search, I found that others had the problem and found a solution with dust caps available as replacements for a folding utility trailer at Harbor Freight. The part number is 93833. It is listed as a 2.305" replacement on the HF website. When I went to my local HF store, it was obvious that the hub on the display trailer was much smaller than what is on my truck and the replacement dust caps are, too. The 2.305" spec on their website is not accurate. Maybe older versions of this trailer had different hubs?
Anyone had any luck finding these? Mine work, but are pretty beat up. I have found spares at salvage yards, but they are not in any better shape than mine.
Maybellene
(Ebay links are still not allowed in General Truck Talk)
My Trucks
Stuff I Collect
' Offline
Maybellene,
I bought these for my 1954 3/4 ton.
They will fit your 1957 3/4 ton.
2 & 5/16" O.D.
see PIC @ photobucket
http://i669.photobucket.com/albums/...rontWheelGreaseCapsGMNOS_zps9d411460.jpg
Original part GM # 3680897
Superseded to:GM # 3768604
Chicago auto parts has ( 1 ) GM # 3768604
Phone: 815-614-3122
Friesens Chevrolet has ( 1 ) GM # 3768604
Phone: 402-773-5538
Hope this helps.
George
in
New Jersey
1954 3600
Now cruising in
The Passing Lane
Bruce and George, thank you. Bruce, I don't have the screw in type like in your picture. George, the ones you show look exactly like what I am looking for. Guys, thanks for the help.
Maybellene
George, I bought the last one from both Chicago Auto Parts and Friesens Chevrolet. Thanks again for the lead.
Two tips I learned from the internet that I thought were worth posting about installing these dust caps. First, put the dust caps into the freezer for an hour or so before installing. This temporarily shrinks them a tiny amount and makes them easier to install. Second, tap them into place with a 2" PVC pipe end cap fitting. The PVC fitting fits over the dust cap and catches the lip. By tapping on the PVC fitting instead of directly on the dust cap, you avoid denting the dust caps.
Maybellene
Denny G
Sandwich, IL
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I bought 2.33" dust caps from championtrailers.com before I posted looking for help. They would not fit...just a touch too large. They look like the exact same ones listed on the pacifictrailers.com website listed above. Close, but no cigar...at least for my truck.
http://www.championtrailers.com/2-33-dustcap/
