| | | Forums66 Topics128,060 Posts1,055,832 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I coming down home stretch with my 58 GMC. I'm almost done with the conversion, 350 probable about 300 hp with 3spd. I pulled the cover off the rear and I have the 3.07 gears. It was originally a 270 3spd truck but when I got it the 270 had been replaced with a 235. After rebuilding the 235 it was to anemic, so I sold it and started over with the 350. I'm hoping the extra hp will make if a little more drivable. I'm not looking for a hot rod just an old truck to drive and use for around town and camping trips.
What do you think, will the 3.07 gears be too tall. I'm also running a 215/75 15 tire. Thanks Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The gears will be fine if you are just driving around and not towing or hauling any weight. If you are going to do any towing or hauling the 3:07 along with the 3 speed might be a little sluggish to get things moving. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | That's what I thought. I don't plan on pulling anything heavier than about 1500 lbs, small camper. Most of the time it will be just the truck and me.Larry
