| | | Forums66 Topics128,176 Posts1,057,058 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | bought the frame this summer with newer style tie rod ends already on it..but they fit in the hole VERY sloppy..quite a bit of clearance between the angled tie rod end and the hole in the steering arm.
Do I have the wrong tie rod ends, or is a good size spacer needed in the 3/4 tons?
Got another front end if I have to go back to the old skool ones.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | If I remember correctly If you remove the fixed ball ends from the original tie rod you end up with straight holes, not tapered.
Sounds like someone tried to make due with some off the shelf parts. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | That is what I am wondering..if I have the wrong tie rod ends. Anyone got a measurement on the shaft of the correct replacement ones? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The 1/2 ton balls have a straight shank on them, the 3/4 ton balls have a taper. The tapered shank balls for use with the standard tie rod ends are available from the vendors. http://www.pbase.com/dennygraham/image/121613827 For the 3600 series there is no modern style replacement tie rod end with a female thread offered by any of the vendors nor does MOOG make one. Moog does make one with the proper taper to fit the steering knuckle but it's has a 3/4" male thread. You would have to make a new tubular tie rod with a male left and right hand thread in each end. The MOOG numbers for the modern ends are ES150R and ES150L. A new tie rod to accommodate these ends is made from 1" x .156" x 43.188" DOM tube. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Whoa..thanks Denny...so I have to make a new tie rod if I want to use the modern tie rod ends on the 3600?
Doable I guess..got some machinist buddies who may help. What are the thread specifics on the 3/4? The left hand die may be interesting to find.
or I could go back to the original ends...I have a a complete extra 52 3600 front end with the old skool ball/socket
Is it worth the trouble to swap?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The DOM tubing is available from any of the online metal suppliers, bout forty or fifty bucks worth. A 3/4-16 RH tap most machine shops will have and they might even have a left hand one on the shelf, if not, McMaster Carr has them for about the same, forty or fifty dollars. Worth the trouble? Maintenance free compared to the original ends, and you gain enough clearance to run many of the tubeless rims that will not clear the original ends. Also the tubular tie rod is much stiffer than the 3/4" solid rod originally used on these trucks.
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | thanks Denny..I'm sure I can pick up tap(s) from machinist buddies, I'll try local metal shops for tubing. If I can't find it here where is a good online source for the tubing in the US?
What year/make trucks did the newer tie rod ends fit? Just curious for cross referencing.
One thing that puzzles me, I'm sure I've seen the same tie rod end listed online for 1/2 and 3/4 ton from a few suppliers, maybe I was seeing thinks LOL.
Appreciate the response. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've bought from Online Metals.com, cost with UPS shipping for four feet was $43.14: http://www.onlinemetals.com/merchan...howunits=inches&id=283&top_cat=0Tap drill for 3/4-16 is 11/16" (.6875"). The 1" .156" wall tube gives you an ID of .688. MOOG ends will cost you roughly thirty bucks each, get the house brand and they will be about half that: http://www.pbase.com/dennygraham/image/154420792Can't give you cross reference, they probably fit a whole shoot load of applications. The ones that are listed that fit 1/2 & 3/4 ton if you note, say straight shank only. Probably looking at Chevs of the 40's???? Not sure but I would guess the earlier 3/4 ton trucks used the same ones that the 1/2 ton did. There were lots of changes after the war when they introduced the Advance Design. Denny Graham Sandwich, IL
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Thanks Denny I really appreciate the input.
Do you have nuts on the threaded tie rod ends that go in the tube to lock it down? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oh yes, you would need nuts to lock them to the tie rod, other wise it would just unscrew and would change TI/TO and in the worst case, unscrew completely. A factory tie rod would have been made from a higher alloy and split with a clamp. The type of set up that I've been talking about is quite typical of that seen on street rod and race applications using this type of tie rod end or Heim joints. So your beginning to see that it taint a cheap modification to make to the 3600 trucks. But it is a very positive set up and as I said earlier, almost maintenance free compared to the stock ends. If they need replacement in the future it's a half hour job at a cost of around thirty bucks. Another advantage is that if you need to replace one on a trip, the ends are available at any auto parts store in any part of the country, if not across the counter, at least within a couple of hours.
If you can believe it, I'm runnin' out of things to say bout this mod, so I hope you got it figured out by now. Denny Graham Sandwich, IL .
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Let us know if you do this Randy, and maybe post a picture or two. I'm one of those 95% purists so I haven't changed my '50 or my '54 to the newer style ends. I just made this tie rod as an experiment on my part to see if I could come up with a clean way of converting the tie rod. Rim clearance is another one of the little problems that we run into when we're restoring a 3600 AD to make it safe to put on the road. By the time I get to the '54 I may just relax my anal tendency's and use this tie rod on it so I don't have to space out the Ford 16" front wheels to clear the tie rod ends. After all, GM already beat us to it half way on the '54 by using a modern style drag link. Denny Graham Sandwich, IL
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Will do Denny..your setup looks pretty neat. One last thought tho..did you look at trying a tri-five 3/4 ton tie rod end? Just wondering. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | ? Don't really know what the tri-five trucks used but if they have a tubular tie rod this might very well be the replacement. I don't have access to a cross reference catalog. dg
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Aren't the tri-5 (55, 56, 57) 1/2 ton and 3/4 ton tie-rod ends the same as the earlier tie-rod ends (I do not know if the ball stud ends are the same in 1/2 and 3/4 ton - I think they are different)?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thought they were also Tim, but I don't have access any square fendered Chevy's so I wouldn't know.
DG
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Thanks..that answers it I guess...
funny..this also has a upgraded drag link and it looks like it fits both the pitman arm and the steering arm very well (right taper and size)..must have been for a 3/4 ton | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | ??? I thought you had a 3/4-ton??? 3600 series is a 3/4-ton you know. Also posted back a bit, that the '54 did use the newer style drag link.
DG
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | No Denny I have a 3/4 ton 3600, the drag link fits good, I was just wondering about the drag link differences between a 1/2 ton and a 3/4 ton...this one fits so I assume it is for the 3/4 ton.
I'm going to try your upgrade, probably order the materials this week. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just added this to show the relationship of the 1" tie rod vs the 3/4" tie rod, which would be the same diameter as the 3/4" thread on the new ends: http://www.pbase.com/dennygraham/image/154464324I don't think there is a difference in the drag link for the 1/2 or 3/4 ton trucks. DG
