1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 23 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 23 | When I purchased my 1948 Chevy 3600 a year ago I found that it came with a full pressure 235. I've heard plenty of people talk about having those engines being rebored to 261 strokers. If I did this how much of a power increase would I get and how hard would it be to get parts? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Impossible- - - - -a 261 has a 3 3/4" bore, and you'll hit the water jacket before you get a 235 bored that big. The 261 has a totally different cylinder wall thickness and the adjoining cylinders are "siamesed" together to allow the necessary machining to fit a piston that big. There are also extra cooling holes in the cylinder head to accommodate the lack of water flow between the cylinders.
A 235 and a 261 use the same crankshaft, so the term "stroker" definitely doesn't apply. The 261 crankshaft can be offset-ground to use a 292 connecting rod for a stroke increase, but a set of custom-made pistons are required to make that combination work. It's possible to get almost 300 cubic inches from a 261 block and a stroker crankshaft with the right piston/rod combination, but get ready to spend mega-bucks to build that engine! Jerry
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I saw a 261 dyno pull on youtube, that had been modified like Jerry stated.
It topped out at 225 Hp, and 330 ft. lbs of torque. Seemed like alot of work for not alot of performance.
Your best bet is to find a 261, stick some 848 heads on it, add a hotter cam, and live with it.
If you want more power and torque, find a 292 and stick a hotter cam in it and a 2bbl. It'll run a 261 under the table any day of the week. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | When I purchased my engine, I thought I was getting a 235. It turned out to be a 261 with an 848 head. It had the starter, bell housing, water pump, carb and everything. It just slipped into the engine bay, no issues. The only minor thing was to put a larger pulley on the water pump, no relocation issues. I am quite happy with the performance, 20 mpg is a bonus. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | When I purchased my engine, I thought I was getting a 235. It turned out to be a 261 with an 848 head. It had the starter, bell housing, water pump, carb and everything. It just slipped into the engine bay, no issues. The only minor thing was to put a larger pulley on the water pump, no relocation issues. I am quite happy with the performance, 20 mpg is a bonus. Bet that was a pleasant surprise  | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | When I purchased my engine, I thought I was getting a 235. It turned out to be a 261 with an 848 head. It had the starter, bell housing, water pump, carb and everything. It just slipped into the engine bay, no issues. The only minor thing was to put a larger pulley on the water pump, no relocation issues. I am quite happy with the performance, 20 mpg is a bonus. 20 mpg?? What differential ratio / transmission are you using? John | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Original 4 speed with torque tube. Diff ratio is 3.55. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | We are talking gallons, not litres?? I may have to think more about going the 3.55 route.
John | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Yes, we are talking about gallons, imperial gallons. Not trying to get off topic though. Just trying to point out how good the 261 is. It is rated at 150 hp, that's with the stock 1 barrel and most everything else stock. There is potential for more, but where does one stop with trying to do more? | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | When you run out of money. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | "There's no substitute for cubic dollars!" Jerry
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | When I purchased my engine, I thought I was getting a 235. It turned out to be a 261 with an 848 head. It had the starter, bell housing, water pump, carb and everything. It just slipped into the engine bay, no issues. The only minor thing was to put a larger pulley on the water pump, no relocation issues. I am quite happy with the performance, 20 mpg is a bonus. One Imperial gallon equals 1.201 US gallons. Are you therefore saying that you are getting 24 miles per US gallon? DO you have a body on this frame or do you drive down steep hills everywhere you go?
| | | | | Joined: May 2013 Posts: 20 New Guy | | New Guy Joined: May 2013 Posts: 20 | Are you therefore saying that you are getting 24 miles per US gallon?
New math? Remember the imperial gallon is larger than the US gallon. 1 imperial gallon = 1.201 US gallons.
20 miles per Imperial gallon = 20 miles per 1.201 US gallons.
20/1.201 = x/1 x = 16.623 miles per US gallon.
Cliff | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Here's the 261 Cadillac article. 261 Cadillac Build
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | When I purchased my engine, I thought I was getting a 235. It turned out to be a 261 with an 848 head. It had the starter, bell housing, water pump, carb and everything. It just slipped into the engine bay, no issues. The only minor thing was to put a larger pulley on the water pump, no relocation issues. I am quite happy with the performance, 20 mpg is a bonus. One Imperial gallon equals 1.201 US gallons. Are you therefore saying that you are getting 24 miles per US gallon? DO you have a body on this frame or do you drive down steep hills everywhere you go?  I don't mean to get off topic. My point was about the 261 engine, that it's a good engine. (My actual mileage to KC and back, a distance of well over 2000 miles was 21.5 mpg, a bit less if you use American gallons. John Milliman was right behind me for the last stretch, ask him about the body or the downhills) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I get 18MPG (USA gallon) highway-driving at 55-60MPH with a 261 and 3.55 rear-end and 31.5" diameter tires. The MPG drops to 12-14MPG at 65-70MPH (most likely a result of higher RPM and higher wind resistance). | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The MPG drops to 12-14MPG at 65-70MPH (most likely a result of higher RPM and higher wind resistance). It's also possible the power valve spring in your carburetor is a bit too strong. When manifold vacuum drops enough to open the power valve, fuel economy goes south in a hurry. What kind of carburetion are you running? Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I got similar results at similar speeds with:
Dual single-barrel Rochesters (too much "carb"/flow at low RPMs) - rebuilt by whomever JC had rebuilding carbs 16 years ago
Dual progressive two-barrel Carter-Webers (no significant "power" at higher RPMs - new from Langdon
Single two-barrel Holley AA-1 (with adjustable jets) - rebuilt by a professional who has a good reputation
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I get 18MPG (USA gallon) highway-driving at 55-60MPH with a 261 and 3.55 rear-end and 31.5" diameter tires. That's exactly my setup and gas mileage. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Are you therefore saying that you are getting 24 miles per US gallon?
Cliff Thanks Cliff. No, not new math, old brain. I did the math backwards. Now the point is that this guy gets about 1.6 more miles per gallon than my stock 216, 4.11 torque tubed 52 3100. I'm not going to challenge him to a race, but we can stop at every gas station together along the way. Carl
| | | | | Joined: May 2013 Posts: 20 New Guy | | New Guy Joined: May 2013 Posts: 20 | Carl Yeah, multiplied instead of dividing. Been there, done that. That's why I like to write the problem out as equal ratios. I figured you would eventually see the error but had to get my $0.02 in. 8~} Cliff | | |
