| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | putting together 350, the power steering pump is threaded for standard (it's not metric I checked), but naturally didn't come with a pulley (parts house rebuild). All of the pulleys I find for sale are for "keyed", while this pump appears to use a bolt on arrangement. I don't have one on hand, so have to order and thought I'd ask, are these power steering pulleys interchangeable? This is for v belt hookup on long water pump 350. thanks for your thoughts (in advance). | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Order one for a '75 - '79 Chevrolet C10 pickup. The pulley is a press fit onto the pump. The threaded hole in the center of the shaft is used to press the pulley on. | | |
