| | | Forums66 Topics128,193 Posts1,057,241 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 5 New Guy | | New Guy Joined: Feb 2013 Posts: 5 | I finally found a 54 235 engine that runs really good and a mech speedo s10 t5 trans. I have a 37 bell housing but i still need a clutch fork and pivot ball as well as a clutch disc and t/o bearing. The disc i know i can have made fairly easy but not sure on the fork and pivot ball. I got an adapter plate from vintage metalworks made for the 37 bell housing. I have been looking for a 37 truck fork and pivot but no luck yet. I remember reading about the 37 fork being a little off center. Has anyone else tackled this conversion? My original 207 has a cracked block and leaks coolant besides the fact that it will do about 50 mph tops and it is screaming at that. This conversion will make it a much more driver friendly truck. Thanks!! Ron.. | | | | | Joined: Feb 2013 Posts: 5 New Guy | | New Guy Joined: Feb 2013 Posts: 5 | | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Ron, MY 37 clutch housing ( picture ) didn't fit my T5. Check to see if the trans will fit your clutch housing. I am using a '50 clutch housing and it came with a 12V flywheel, starter, and clutch forks. ebay clutch fork I'm just giving a heads up. Bread . | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You do not want a 37 fork, it is designed for a carbon throwout bearing. 1938 and up use the ball bearing style. You do not want a 37 bellhousing either, as the pivot ball is in the wrong place for a 1938 or later fork. A 1938-47 truck bellhousing is what you want.
See the USA in your vintage Chevrolet! My Blog | | |
