Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 557 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
I have a beautiful little '54 Chevy 210 with the 6v. 235 engine. I'm doing my first real tune-up. Have adjusted the valves, replaced all electrical components and now want to set the correct dwell and then I'll do the timing. (currently I'm getting a reading of 28 degrees dwell and that "sounds" pretty good, but I'm guessing) What should the correct settings be? Can't seem to find it in the shop manual.
revted47,
I show a gap of .019 equates to a dwell angle of 31&deg-34&deg. Your pretty close!
Stuart
Thanks, I've set it to 32-33, now for the timing - what should the settings be?
revted47,
I think the factory intended the engine to be timed dead on the ball on the flywheel. Although the this is commonly called TDC, I actually think it is somewhere in the neighborhood of 3&deg advanced (I think). I would use a light and time to the mark on the flywheel..this is done with the vacuum disconnected and carburetor plugged.
More advance will give your rig more oink, within reason. You can keep inching the advance forward until you hear slight pinging under a load, or until your operating temperature creeps above the normal figure. If you have an advance timing light, you will be able to dial in actual figures...try 8&deg BTDC.
Stuart
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.069s Queries: 13 (0.067s) Memory: 0.6042 MB (Peak: 0.6407 MB) Data Comp: Zlib Server Time: 2025-09-22 07:24:29 UTC
Valid HTML 5 and Valid CSS
