0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I saw a 57 Gmc 1/2tn.It has a different rear end than a chevy. The truck has a v8 and hydra matic transmission. The rear end looks like a Dana,could this possibly be a factory rear. It looks like it was always in the truck. Any ideas,thoughts.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All of the GMC's I have seen have the Dana.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The most common rear in a 57 would have been the corporate rear which was 3.90. The third member will bolt right into a 54 and earlier torque tube banjo housing. An option could have been a Spicer 45 at 3.92 or a V8 with an automatic could have been a spicer 45 at 3.07. The Spicers have the carrier built into the banjo housing instead of a removable 3rd member and more closely resemble more modern rears. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I would imagine that it would interchange with a chevy,The 3.07 gear would be nice to have on highway.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2012 Posts: 19 New Guy | | New Guy Joined: Dec 2012 Posts: 19 | I have a '65 GMC pickup rear in my '57 3200 and it's a Dana 44. If that's what you have in yours, parts are readily available and there are an assortment of gear choices. I just recently had a 3.54 and posi in mine. Only problem is that I'm having difficulty in finding brake drums for it.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Although the Spicer may have been standard, that doesn't mean that many of them were specced with them. Tubeless tires were also standard in 1957, but most people opted for a tube required tires. Corporate rears are much more plentiful in Blue Chip series than Spicer rears. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used the 3.07 from a '59 GMC in my '56 Chevy. I had trouble finding good brake drums. The Chevy spec shoes, cylinders etc will work but drums won't interchange. Also had to move the tab for the brake hose from one side to the other. | | |
