| | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 9 New Guy | | New Guy Joined: Dec 2006 Posts: 9 | I'm new to the old truck bug, but I've been bitten hard. My question is this. What's the difference between a regulator and an alternator? Which is better and why? I recently bought a '55 235 for my '49 3600 and I think someone said these were 12 volt, but I'm not sure. I want to deep the truck stock appearing, but I would like some modern upgrades (i.e. wipers, radio, etc.) which route should I take for this? Thanks for any help.
If you think you can't, you're right. If you think you can, you're right.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | An alternator produces electricity and a regulator regulates the amount of electricity it produces.
Which is better and why? I don't understand your question. They are used in conjunction with one another.
Whether the '55 engine is 12V depends on if it was from a car or a first series or second series truck.
Your truck can easily be converted to 12V if you want 12V wipers and radio. You can use either an alternator or generator. A generator will be fine with just those accesories. If you go to adding things like A/C, power seats/windows and the like, go with an alternator. | | | | | Joined: Dec 2006 Posts: 9 New Guy | | New Guy Joined: Dec 2006 Posts: 9 | My bad, I meant the difference between an alternator and a generator. The motor is from a '55 car that had a powerglide so it should have the hydraulic lifters, if I remember right. I only plan on the wipers and a radio. They didn't make trucks with A/C back then, so it seems kinda silly to spoil the whole point of an old truck by adding the A/C. Thant's what the big glass things on the doors are for of you get hot, right?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 55 woulda been 12V, and a generator will have no problems running any accessories you might have, as they did in the day, the main advantage to an alternator is lots less maintainence
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The motor will have 12 volt gen. & coil. The original 49 is 6 volt. If you use the 12 volt system (preferred) you will need to convert rest of the system. The gen is more original but the alt charges at a lower RPM & is more reliable. The alt is a good idea if you will be in parades or heavy traffic. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
