3 members (Gray_Ghost, Steelonsteel, Gdads51), 46 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#1001446 01/23/2014 10:07 PM
I have a noise that I cannot locate currently so just as a thought, can I drop the oil pan and re torque the rod caps?
The noise I thought was the driveline coming separated at the yoke so I disconnected the drive shaft cover and tightened those 4 bolts with a drop of thread locker. The u joint could be swapped out so that is on my shopping list for future.
5/8 ton #1001447 01/23/2014 10:11 PM
Whether you can or can not drop the pan depends on the engine and what vehicle it is in.
5/8 ton #1001450 01/23/2014 10:36 PM
Sorry. 1947 3100 late full pressure 235
5/8 ton #1001451 01/23/2014 10:37 PM
I do have a 4" drop axle on it
5/8 ton #1001465 01/24/2014 12:00 AM
1 Offline
If by chance it is a rod, re-torquing it at this point won't fix it. But you can check other things while your inside the engine...crank thrust, cam thrust, broken pistons skirts, etc...
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
If its a rod you can have it running and pull spark plug wires to narrow down which cylinder is making the noise. You are better to diagnose a little more before taking things apart. I my opinion anyway.
Thank you I will try that
The late model 235 has insert-type rod bearings that cannot have the clearance adjusted by changing shims like the older Babbit bearing rods could. By the time a knock becomes audible, there's a possibility that too much crankshaft damage has been done to correct the problem even by changing the bearings. Once the pan is off, inspect all the rod bearings for wear, and measure the crankshaft journals with a micrometer for wear. They should be round and straight, with little to no visible scoring, out of round, or taper wear.
Other possible sources of a knocking noise can be worn main bearings, cracked or loose-fitting pistons, wrist pin wear, or foreign matter or carbon buildup on top of a piston causing contact with the cylinder head. Does the noise only happen with the truck in motion? If so, it's probably not an internal engine problem.
If a con rod needs re torque there will be chunks in the oil pan, if the nuts/bolts are not tight it won't last long.
Is it RPM dependent? At idle only or worse at speed?
Do you have a mechanics stethoscope (harbor freight sells an OK one for a few bucks). That can help narrow it down to a cylinder/top/bottom end.
To help locate it I would remove the fuel pump and the fan belt.. anything external to the engine that makes noise and run the motor using the stethoscope and listen to the motor in a systematic way... the closer you get to the noise the louder it will be. Its a fairly helpful tool.
You've already rules out valve lash and done a compression test?
