0 members (),
87
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | My '46 Chev p/up has factory 4-speed transmission. I drive it as a 3-speed. My question is about terminology. Some refer to low as "granny" low. Others call it "stump puller" low. Am curious as to what is the generally used term. Thank you in advance for any & all input
sandra | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sandra, First Gear is the term used by GM. The other names are cute and informative. Granny Gear is a common description/name. Although, at the same ages, my Grannies moved faster than my Gramps. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Unless you are from New Jersey and then its called Foyst! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Some people call it "sub low" because, unless they have a heavy load, they treat second gear as their low gear.
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | "compound" is another term used used for lo gear.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | In my dad's old K30, the shift knob said, "L." It then went, 1,2,3, and R. | | | | | Joined: Sep 2013 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 61 | I've got a Land Cruiser with a first gear that's good to about 5 km/h. My dad referred to it as "bull low", which seems to be the norm in my area.
Whenever you leave behind failure that means you're doing better if you think everything you've done has been great you're probably dumb -Louis CK- '53 GMC | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | My neighbor used to use his 62 C-10 and a flatbed trailer to pick up hay bales by setting the hand throttle to fast idle, putting the transmission in granny gear, and using a bungee cord between the steering wheel and the seat frame. He would walk along beside the truck and toss bales onto the trailer until it got near the end of the field, then turn it around, and walk back the other way. Jerry
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Maybe it should be "walking gear" cause that is what you get from it. Dad called it compound when in a good mood. Other things when he was not so happy. I do the same. He was a very good teacher.  It will pull stumps, bigger trucks and if you have traction...cars from mud. Just not very fast.
Steve H
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I pulled a air-cooled VW out of a almost vertical ravine using an SM420 in 1st gear (granny gear) and a strong cable.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | In the great state of Wisco, we use to call it the Creeper Gear. Some farm implements require you to drive very slowly yet with high engine revolutions per minute (RPM) in order to have the power take-off (PTO) shaft spin at the proper RPM needed to drive the implements mechanism at the desired speed. Such gears are usually not synchronized.
“Nothing like a farm. Nothing like being around animals, fixing things. There’s nothing like being in the field with the corn and the winter wheat. The greenest stuff you ever saw.” | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | I learned to drive in a 1974 Chevy K10: short box, full time 4wd, heavy duty springs, no radio, no carpet, etc - you get the picture. It was a work horse and it road like a log wagon.
The gear shift knob was labeled: L . 2 |--|---, 1 . 3 . R
"L" was non-synchronized and the engine rev'd out between 5 and 8 mph when the truck was in high range. In low range, it was half that.
Dad called "L" a "granny gear" or "granny low". In "L" and 4-low, the truck would spin its wheels before it would stall. Loved that truck.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Back in the latter 80's, I used the infamous granny gear to pull a couple oak tree roots out of my front yard. Here's a couple pics taken of the end of the propeller shaft afterwards. No, I'll never do that again. Had to chop off and keep the splined section for a keepsake. Twisty 1 Twisty 2
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | One of my friends who ran a small machine shop in central California had a 12" section of 4" driveshaft tubing hung from the ceiling above his lathe. It looked like an hourglass, with three complete turns twisted into it. A driver of a Peterbilt tractor stuck in a muddy field hooked to a double trailer load of freshly-combined rice wound up his 425HP Catepillar engine and dumped the clutch trying to get unstuck. The transmission output shaft made 3 turns before the shaft shortened up enough to pull a slip yoke apart! The rear wheels didn't move! Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I learned to drive in a 1974 Chevy K10: short box, full time 4wd, heavy duty springs, no radio, no carpet, etc - you get the picture. It was a work horse and it road like a log wagon.
Bill Rare truck. GM only made that particular transmission/transfer case combination in '74 to early '75. From what I understand, they had too many problems with snapped chains in the full time t-case from drivers dumping the clutch in Low. All later full time trucks were automatic trans only, manuals got the gear drive NP205 part time.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 37 | This part of the country they refer to that as low or granny gear and compound low refers to a 4WD in low gear and the transfer case in low range. My 76 Suburban had that setup and there were very few situations I needed it, but when you do it is great. It would crawl along at a very slow walk.
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Back in the latter 80's, I used the infamous granny gear to pull a couple oak tree roots out of my front yard. Here's a couple pics taken of the end of the propeller shaft afterwards. No, I'll never do that again. Had to chop off and keep the splined section for a keepsake. Twisty 1 Twisty 2Wow. Who would have thought you could do that!
Never, never, never, never give up. - Churchill | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | I learned to drive in a 1974 Chevy K10: short box, full time 4wd, heavy duty springs, no radio, no carpet, etc - you get the picture. It was a work horse and it road like a log wagon.
Bill Rare truck. GM only made that particular transmission/transfer case combination in '74 to early '75. From what I understand, they had too many problems with snapped chains in the full time t-case from drivers dumping the clutch in Low. All later full time trucks were automatic trans only, manuals got the gear drive NP205 part time. It "ate" u-joints. I remember backing it out of our driveway, the truck would twist and buck when the steering wheel was cranked over to the right turn stop (paved driveway to paved street). Looking back, I should have know better, but that's how Dad did it. One summer we had to have all 6 u-joints replaced. We didn't use low often and eventually put a Warn part-time conversion kit into it. It almost doubled the gas mileage in town.
Never, never, never, never give up. - Churchill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Premature U joint failure was a common problem on the full time trucks, even the automatics. The twisting and bucking is also a problem with those, though I don't recall either one of the 3 full time trucks we had doing it too much. But I have seen it on trucks and suvs I've had in the shop, especially Quadratrac equipped Jeeps. Even the modern 4x4s with the "automatic" 4x4 systems will do it "auto" mode, which is really just a variant of the old full time system, using a fluid clutch instead of a center differential.
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | There's a good reason for the twisting and bucking a 4WD with Cardan-type U joints does in a tight turn. (They're the ones with the cross-shaped center, not CV types). A Cardan joint can only flex through a very limited range of motion, and if it approaches its limit, something has to give- - - -either the angle of turn must straighten out, or something will twist or break. On loose gravel, ice, snow, or such, the tires slip and squirm, providing relief for the bind. If the tires get a good grip on dry pavement, joints break, shafts or frame rails twist, or the steering wheel bucks back against the driver's hands enough to relieve the bind. That's why front wheel drive vehicles must have constant velocity U joints that can turn through a larger range of motion without binding up. A Citroen 2CV front-drive car has Cardan-type U joints in the front axkes- - - -anybody ever driven one of them? They squirm and wobble around every turn! Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Can't say that I've ever had the opportunity to drive a 2CV, Jerry. Sound like a lot of fun in the turns. Now that you mention it, though, something I always found odd was that when GM went to Spicer sourced front axles for the 4x4 models, they went form the Rzeppa constant velocity joints to the Cardan style. To me, that looks like a backwards step as far as performance. Only advantage I see is reduced cost. Jeep did the same thing, though the later downsize Cherokee did go back to the CV joints towards the end of their production with solid axles.
Bill Burmeister | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Miss Churck In the corn belt we call that gear dual low. Low axle. lowest trans gear,thus dual low. | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | Up here in the mitten state we call it creeper gear or granny gear, my first new truck was a 1974 GMC K1500, 350 engine, full time 4wd, sm465 trans. I was a senior in high school and got tired of wrenching on my '67 C-10 so I bought the '74 off the dealer lot.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I call that gear my parking brake. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
