4 members (Tim Canfield, Bill Hanlon, Hotrod Lincoln, 55shaker), 108 guests, and 4 robots.
Topics128,195
Posts1,057,380
Members48,469
#1001220 01/23/2014 1:12 AM
65 stepside. New 350 crate motor from summit. Carb rebuilt, new wires, plugs, coil. Anything above idle starts to miss. Dwell right at 30. Timing tried 4 to 10 no help. Any suggestions welcome
Riding in the Passing Lane
Try it with the vacuum advance disconnected. I have found these engines run rough when they get a lot of advance.
1972 Chevy c10 Cheyenne Super
make sure there isn't crossed plug wires.
I would ditch the vacuum advance all together. Especially if it's an edlebrock.
ojh Offline
So its a points distributor? Try another capacitor/condensor they'll affect it; is the coil overly hot? its' easy to get a mismatch with the coil and ballast resistor nowadays and the ignition will pull too much current and act all wonky.
I recall an ohm reading of about 4 - 4 1/2ohms is about right - i can easily be wrong, maybe somebody else can chime in on it. The coil will be less than an ohm and the ballast resister is sized to the coils' resistance. back in the day the local napa had all the right stuff laying around and took care of you and you didn't even have to know about it, nowadays you're lucky to find a ballast resistor of any value.
just a thought.
A shop is where you wash your hands before you pee.
Timed port vacuum, or manifold vacuum? It does matter. Crossed or damaged wires? Bad gasket at carb to manifold. Loose points, or reluctor...The list can go on and on. Fix 1 thing at a time. Test and continue until you find it. FYI, Coil and ballast are matched by resistance. If the coil reads 2 ohms use a 2 ohm resistor. If the coil reads 4 ohms then use a 4 ohm resister. How to tell an internal resisted coil? If it still has markings it will tell you if it does not...I don't know.
Steve H
How about doing a power test? At warm idle, pull plug wires one at a time and listen for the RPMs to drop. Any cylinder that doesn't drop isn't producing any power, and has an issue. (duh).
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
