3 members (Gdads51, Gib70, 1 invisible), 86 guests, and 0 robots.
Topics128,078
Posts1,055,935
Members48,430
Some time ago I noticed a set of these plug and play lights in the Filling Station catalog... No wiring req as they had a plug right on the end of the wiring which fit nicely into the bulb socket. I finally got around to ordering them and it seems those were discontinued..or at least not supplied by their supplier and the ones I got require hard wiring
Anyone know about this and if the original ones with the plug are still available anywhere ?
Filling Station catalog still shows the ones with the plug on the end but they say they forgot to change that in their catalog...
Wonder if they just didn't work well ?
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Mark,
Which 1949 bulb are you looking to replace?
Do you want a 12v or 6v LED replacement bulb for the original 6v bulb/socket?
The ones you talk about exist in 12v, if you mean the ones with the lights on a board and a pigtail with socket attached. Check a hot rod parts supplier. If you're talking 6V, I can't help.
My 46 GMC on Photobucket
Yes, I was talking about the 12v ones...but just went ahead and hard wired the ones I was sent. Filling Station used to carry them but don't have them now..with the plug attached, I mean...
Mark
1949 Chevy 1/2-Ton
Lucielle
I think Chev's of the 40's has the ones you were asking for, in case someone else comes looking.
