0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I have a 1965 C20 with the original wood in the bed. There is a date (I assume it is a date) stamped in the wood near the cab that says "6 (I think) 31 65". Is this the date of manufacture of the truck? If not, what does it mean? I would appreciate anyone's input.
1965 Chevy C20 Stepside
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Don't know that I can help with this question otherthan to suggest the Stovebolt Bed forum and contacted Mar-k. I am interested in the answer. HB | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thank you. I didn't realize there was a Bed forum. I will do that. I will let you know what I find out. Rob
| | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | We have always ASSUMED that that date is the date that the bed was assembled, not the build date of the truck.
Can you post a photo of the stamp? | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 |
| | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | Did you get a reply from "Bed Dept" ?
I'd call that a March 1 1965 bed assembly date, maybe that "C" or is the shift or?
Not too many beds still have that stamp legible! Be interesting to compare with some other casting dates on the truck and the engine assembly date if still original. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thanks Rick. Maybe I should send the question directly to the Bed Dept. You are probably right about what the numbers and letters mean. I will see if I can find some other dates. I know the engine was rebuilt but I believe it is the original engine. Do you know where the date is located on the engine? Thanks for your help. Rob
| | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | If it's a V8 it's on a pad in front of the right cylinder head, a six, I believe it's next to the distributor. Should be a letter and a few numbers and then a couple letters. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | It's a 292 6. I'll check next to the distributor. Thanks.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I believe the date-stamp on the wood, represents the processing/machining of the wood, whereas the date stamps on the motor, represents the manufacture date of the block, not the installation of the motor into the vehicle.
| | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | My bed wood "date stamp" reads: AMP3 14 66. Not sure exactly what it means, but I do know the truck was assembled at Fremont, CA on 4/1/66. | | |
