| | | Forums66 Topics128,078 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 25 | I have a 51 chev pickup, and I'm changing the motor from a 216 to 235ci. its out of a 55 chev with auto trans. So it has solid lifters and full oil pressure. I took the motor apart to clean everything and check bearings. and so on. I took the oil pump apart to check gears and misplaced the gasket! I read where you need to get a gasket from Chevrolet. nothing else will work.(true or false)so where do you get a gasket for a 1955 235ci from Chevrolet mafg. | | |
