i installed the rocker arm assembly into my head today. i noticed that there is a 1/4" gap between the rocker arm and the push rod. that's after i adjusted some of the slack out.
my motor is a hydrolic lifter 235. i compaired the lifter legnth to a solid lifter 235 that i have and they are the same.
my question is are the lifters supposed to be the same legnth? and if so. where might my problem be then?
