| | | Forums66 Topics128,260 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 47 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 47 | Currently installing a 350 with a short tail 350 trans behind it in a 39 1/2 ton. Using a cp mount system that fits with a little work to narrow to fit frame. Another issue is getting exhaust to fit in frame area and clear steering box if you intend on using the original front end. You can fit it in to clear steering box and clear the radiator. It will be close but can be done. Using a rear end out of early Camaro that fits . Just had driveline made and working out rest of issues.
Ed | | |
